2000 Neon Transmission
1996Eclipse420a
162
Jan 12, 2012
Wilkesboro, North Carolina
I picked up a used 2000 neon transmission. My 5th gear went out and would not stay in gear at all. I use atf-4....
Now the gears are taller in the neon transmission if I'm correct. My question is, is it a noticeable difference in torque? I running 15lbs of boost.
Second do I keep my speed sensor and gear from my old transmission or do I leave the neon speed sensor in the transmission? I don't want my speedometer to be off.
Ooops I just realized I posted this in the wrong forum. I apologize
Never mind. I've figured out everything I needed to know except one thing. The motor mount that bolts on the gear box side of the transmission... can those be swapped out with the N/T Eclipse one? Because the 2000 Neon one is completely different.
I used all the OEM Eclipse mounts when I did my swap.
Some will disagree but I only run the OEM Mopar fluid in mine.(Not ATF)
Link to OEM fluid.
[ame="http://www.amazon.com/Genuine-04874465-Transaxle-Quadra-Trac-Lubricant/dp/B000TWF1SK"]http://www.amazon.com/Genuine-04874465-Transaxle-Quadra-Trac-Lubricant/dp/B000TWF1SK[/ame]
    • 4g63tv
    • 4g63tv
  • For sale 2g 99 2G parts
