NEED SUSPENSION HELP and SHOCK
Charles1
160
Oct 24, 2003
well i went back to stock height and though i installed my springs right but guess again something i s way wrong It turns out my shock or the shock where it hold the bump stop and all that it stcks out way to far up that my hood gets hit. i know im missing a peice i guess if its doing that. so all i need to know is a diagram or a picture better that shows me the components of the suspension assembly to see what i am missing.
the only peice i know I am missing is that boot dust thing. i though that was only to prevent dust from getting inside shock is it meant for something else like the problem im having if so let me know. but yes i need a diagram that difines all parts that i need a shop is cahrging me 300 for fixing this i know thats too much so any help would be helpfull.
the part im missing is shock b ellows is that need to fix my problem at first when i tossed them when installing coil overs i thought it was dirt boot you know so if thats what i nee dto fix my problem let me know. thanks asap or if your selling you whole spring and assembaly ill buy it but cali residents only dont want to pay shipping
Which shocks did you get? I had the same problem when I put it my Konis - they come with an upper and lower washer for the shock shaft, but the lower wouldn't fit, so I didn't use it. As soon as I backed out the driveway, the front right shock punched a dent in my hood. I went back and drilled out the holes of the lower washers to make them fit, and it's been fine since. I've talked to other people who had the exact same problem.
