need help broke rear shock bolts
It is the very bottom bolt that goes into the spindle (I'm guessing). The top should be held in by studs/nuts. I have broken that bolt (due to rust) and ended up drilling. I didn't waste my time with an easy out or anything. Its not pretty, and its annoying, but try to get the center drilled out and work from there.
Matt
Matt
How did u get the drill up in there
Will do
Yeah thats the bolt I thought you were talking about it. It isn't real hard to get a drill in there at about the same angle as the camera. You may try one of the smaller propane torches (you can pick up the little kit at Wal Mart) and just use the heat on the bolt itself. It doesn't look that bad, may be able to heat the **** out of it and run an easy out in it.
Propane isn't going to do anything to that bolt. I would spray it down with wd40 for a few days than weld a nut to the part sticking out. The combination of the lube on the threads and the high heat from welding a nut on the end should loosen it up.
i dont have a welder. i do have a propane torches. will that burn the rubber part at all???
Propane isn't neat hot enough to help with that at all. You are going to need to get it glowing to loosen it up at all. You will want to remove the stock from the arm before you add any heat. I reccomend finding someone with a welder and a torch to help you out.
I would get that shock off first and see what you have left to deal with.
If memory serves me right, there is a sleeve inside the rubber which the bolt was holding in... I don't know that removing the rubber will help you as much as drilling it out.
if your replacing the strut just pry it off if it wont budge cut the lower part of the circle mount off with a cutoff let it hang down and try to get the rubber off and back it out with vice grips... if you can heat it enough melt a wax crayon on it it will sometimes work its way into the threads and act as a penitrating oil
DO NOT USE A TORCH on the tube of the shock for any reason!!!!
Ask me how I know......took about a year for my eyebrows to grow back.
