apocalypsio
- 34
- 0
- May 2, 2010
montreal,
QC, Canada
Hi, I haven't been able to get my car to idle right ever since I've had the car
. I changed the whole engine to a 6 bolt 1g, got the car running right got rid of all boost leaks recently just changed the tb to a 1g tb with new shaft seals and new gaskets . I did also a terra clean to clean out the injectors and all the crap in the fuel system.You can look at my mods in my profile its up to date.
The car doesn't run to bad, I just can't get the idle stable its not surging but it jumps around too much and fuel flow too , plus there an arcing sound. thought the spark plugs and spark plug wires are new.Also the o2 sensor is brand new as well. I'm posting a log hopefully someone can enlighten me because I'm out of Ideas.THanks
. I changed the whole engine to a 6 bolt 1g, got the car running right got rid of all boost leaks recently just changed the tb to a 1g tb with new shaft seals and new gaskets . I did also a terra clean to clean out the injectors and all the crap in the fuel system.You can look at my mods in my profile its up to date.The car doesn't run to bad, I just can't get the idle stable its not surging but it jumps around too much and fuel flow too , plus there an arcing sound. thought the spark plugs and spark plug wires are new.Also the o2 sensor is brand new as well. I'm posting a log hopefully someone can enlighten me because I'm out of Ideas.THanks
