need some lsd info
all - about 90% have lsd, crawl under the back of the car and see what the tag says on the rear end - should say lsd right on it.
think you can look at the tag on the door also but I am not sure what it says...
If you can't find the sticker or if you want to see if other cars have a LSD you can jack the rear up have both tires off the ground and spin one off the tires. If it has an LSD the other tire will spin in the same direction. If it is not LSD they will spin in opposite directions.
no sticker and the wheels turn to different ways .Were could I find an lsd rear end?? what years do they come in???
