Need some suggestions
tintedglasses12
85
Feb 24, 2009
Belfast, PE, Canada
I want to get my engine rebuilt. I have looked at Mach V, Magnus Motorsport, and Howell automotive. I'm looking for the rebuild kit
Depends on what kind of rebuild you want. Stock or stroker? If your just going baqsic get the topline kit off of ebay. Its a complete kit and it works well Ive used it on a few different dsms with great results.
well I would like to in the future put a bigger turbo on it. Perferably a Precision T & E GT3582R Turbo(rated at 640hp).
Part Number: GT3582RLE
Max Rated HP: 650
Inlet/Outlet Size: T04E 3"/2"
Bearing System: 360 Race
Compressor A/R ratio: .7
Turbine A/R ratio: .63
Garrett Compressor Wheel Trim: 56
Garrett Turbine Wheel Trim: 84
Garrett Compressor Wheel Specs:
Wheel Trim: 56
Wheel Diameter: 82mm
Compressor Inlet Size: 3"
Garrett Turbine Wheel Specs:
Wheel Trim: 84
Wheel Diameter: 68mm
But if i do this I would have to have forged everything right. And to make her a stroker I wouuld have to run a higher octane and all we Have on the Island is 91 octane
