1G Need some help stock fuel gauge 1g
ant_turbo
36
Aug 22, 2005
west covina CA, California
My stock fuel gauge on my 1g talon always reads full. I'm pretty sure the gauge is working when I disconnect the plug for the fuel pump the gauge will go to empty but once I plug back the plug for the fuel pump it goes straight to full.
I do have my Deatch Works 320lph rewired. Thanks
The sender - not the pump. The fuel level sender in the tank is either stuck in the full position or it is shorting to ground (yellow wire).
Here is a pic does anything look out of the ordinary
Do you have FWD or AWD?
I don't have a 1g but according to the manual the all yellow wire is the sender (going to your red connector terminal insulator). The yellow-blue is the low fuel level thermistor (yours connects to that bright yellow). Black is ground.
