Need questioned answered!
91_laser
100
Jun 23, 2002
Stoughton, Wisconsin
Doing a 6 bolt swap in my 93 talon awd cuz 7 bolt took a s***. But while looking at my stock CV axle for my drvers side i noticed it was a half shaft that bolts to the block. Question is does the 90 block have those hole there also cuz the 90 block is out of a FWD.
Yes all blocks have those holes. You may have to change to the 90 axle or whatever depending on your tranny.
I do think that all DSMs have the same axles tho so you should be good (anybody know for sure?)
only difference might be the length on passenger side but from what i have learn and seen FWD drivers side is a straight axle but the AWD has a carrier bearing that buiolts to the block
that was what I was thinking but wasn t sure so I sought out a wiseman like yourself for the truth
