turboglenn
- 6,375
- 124
- Nov 5, 2007
RIpley,
West Virginia
This week my alky injection kit will be here and my cams as well.
i plan on base lining my car on the dyno before installing them,
then after the install I'm going to tune to the same boosts on pump gas alone for a comparison on the 264/272's over stock
then I'm cranking the boost and adding some timing ( i hope ) when i ordered the kit Chance had told me that 1-2lbs more boost and 2 degrees more timing was a typical improvement. I had been under the impression that i could run much higher boost and timing ( I'm thinking 22-24* timing and 23-24 PSI ) I'm going to be rather disappointed if i can only gain 1-2 psi and 2* timing in the top end
You guys that run alky injection..how much timing were you able to add and how much more boost are you running without significant knock? I can't monitor knock unless i'm on the dyno and i'm going to base tune on the street before going back to teh dyno for the full test of teh cams and alky injection. I hope to have some very nice dyno sheets afterwards, if not i'm burning the car
