Tuning AFR with methanol injection
LTUDSM
1,802
7
Jun 27, 2005
Morrisville, Pennsylvania
What is the AFR using 50/50 mix of methanol i could be seeing during WOT pull?
here is the WOT log only on pump gas (93 octane)
12.0 is recommended with the meth kit. Also don't bother with the 50/50. just run 100% meth.unless you raod racing this thing
I talked to the Tech service at snowperformance,and they said,that 50/50 is the best mixture to go with.Also they said,that running 100% methanol wont gave any gains the running 50/50mix.... So why waste methanol???!! Its ain't cheap LOL. And not every store has it :p
BTW 12.0 AFR is on a lean side? or i could go a lil bit over 12.0? Like 12.2 or 12.3?
Ya they don't want you to burn your car down thats why they recommend 50/50. All I can say is my car knocked less with 100% meth and I was also able to turn the boost up higher.you'll find out. Phone aquamist.....they say 100%meth.
And yes you could lean it out to 12.5afr but you better have everything working top notch and also see if your car likes it mine doesn't but yet the water meth companies say this afr is possible
