need justin or 16g wizards
BoostKrazy
251
Apr 3, 2012
PHX, Arizona
I have a ebay 16g, bolted it all up and screwed the stock feed line back in.. started the car and oil spewed out.. i cant find anything that will fit in that hole that will fit in that hole.. i cant afford to wait 5 days for a shipped item, really just need to know the size/thread pitch so i can figure something out.
Oil spewed out of the stock line? Take the stock line in to the parts store or wherever you are wanting to go for the piece you want and have them match it up.
Did you install copper crush washers on the bango bolt feed line fitting?
An Ebay 16g will have a smaller banjo bolt that goes to the turbo than the stock mitsu banjo bolt. I had to order an ebay oil feed line and banjo bolts from a member on here. You could also try a seller on ebay.
I believe the thread and pitch are as follows- 10mmx 1.25
Maybe someone came chime in and confirm the banjo bolt size for it.
Sorry, i had a question about my 16g, so i put the title so justin (king of everything turbo on this site) and 16g wizards (pertinent to my thread) could read it..
It's in the turbo tech system. I'm pretty sure this is the one section that Justin checks out almost every single thread. You can pretty much be assured that he'll see your question even with a proper title :)
Soooo mark this thread resolved and/or move it to the Graveyard with the other poorly-titled non-searchable threads?
If you think it's a non-common question, I'd change the title to reflect the actual question and mark as Resolved. If not, move it.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
