need info
syncere129
62
Nov 20, 2008
baldwin, New York
well my qustions is about a couple of things.
first if i was to purchase a fpr do i also need a afpr?
second question is can i eliminated my stock oil pressure sender and just install a new one and just run new wires to the new unit and and gauge?
or could someone tell me a good place to find fittings for it.
FPR=Fuel pressure regulator; AFPR=Adjustable FPR. They are the same thing, you can't run both. Pretty much any aftermarket (aeromotive, paxton, fuelab) is adjustable, and that is the kind you want. As for the oil pressure sender the short answer is yes. You can can buy an aftermarket oil pressure gauge (preferably electric) and just thread it into the stock sender location. Some will argue you need to remote mount it (off the block) when using electric b/c the vibrations will kill the sender; I've had good success with all mine directly mounted.
If you purchase an afpr, adjustable fuel pressure regulator, you don't need to buy another fuel pressure regulator.
As for the stock oil pressure sender, you can disconnect or you can go the a tee fitting you can find at summitracing.com
You should keep your stock fuel pressure regulator unless it is malfunctioning or you are doing some upgrade mods which will require a 255lph fuel pump. You will also need to purchase a guage for your afpr.
ok i already have a fpr it has a gauge on it already,just wanted to know which would be better for future horsepower.
and as far as the t fitting i dont know exactly what size would fit in the stock hole the oil pressure send is in right now.guess i have to take it out and go match it then.
thank you guys very much
