Need some info
dsmsucks
660
4
May 14, 2005
Rochester, New York
As some might know I will be replacing my clutch real soon. So far I know i have to do the following
replace fork and ball
replace throwout bearing
new flywheel
Is there ANYTHING else im missing
Thanks
I'd assume the flywheel doesn't come with new bolts. Don't skimp if it doesn't. Get new ones. Sounds like you are square on everything else.
Agree about the cylinders. I was going to replace just my slave, but was told not to, as it would just put more wear and tear on the weakest part (the master at that point). So they should both be replaced at the same time.
Is this true, because the slave is awfully easy to get to, and the master is awfully not!
It's sound advice, but (knock, knock) my master's still intact three years and two clutches after the slave was replaced. I don't believe that there are many things that are like the timing belts and brake pads that need replacing before they're needed.
  • For sale 1g 1g 90-91 fiberglass hood
    Got this hood new in 1999. While it was fresh I reinforced the fiberglass webbing on the bottom...
