ECMlink NEED HELP WITH TUNING MY SWAP
dc90ms
97
Nov 1, 2006
harrisburg, Pennsylvania
sooo after years of working on this thing i finished it. it is a 06 legacy with a 4g63 rwd! now comes the tunning, i can make anything but when it comes too tuning i cant. soo the air fuel is all over the place can some one help me out?
1200cc injectors
hx35 turbo
speed density
255 pump
i think i dialed int the idle
base timing is at 5
here is a log i just ran thanks!
ecmlink
Idle looks good. TPS is just a bit off but no big deal. Adjust the biss so your iscPosition is at 30 fully warmed up when fan is off. I'd check your charging system. Only at 12ish volts
1) LC1 WB switching should be 2.44V instead of 2.49V
2) Lower your CEL trigger for knock down to 1° and temp to 220°ish so they give you warnings before things are going BAD
otherwise looks pretty standard... take a short drive and use the adjust tool a few times. that should help you get going in the right direction...
    • Sdcryan1
