need help with msd coils
gsxeclipse95
Apr 8, 2005
Pawtucket, Rhode Island
I've been looking for a new msd coil for my 95 gsx, and I'm not shore witch one is best for my car and will fit. On their web site msd has a direct bolt-on 4 tower pack but there are two different models, one with round terminals and one with flat terminals. I've heard that this one is best, but I also want to put on a dis-2. If anyone can point me in the right direction that would be helpful. :dsm:
are you talking about this
if so, this is for the 2g non-turbo one that carry 420a motor
some guy at a local autoparts store told me that one if for the 420a motor and one if for the 4g63. And msd is taking forever to respond to my question. so now that the stock replacement coil is out I think I have no clue. dose anyone have any recommendations? Will the stock coil hold up with a dis-2 installed? Do I need a aftermarket msd coil? Witch one is best for the 4g63 engine? :confused: :dsm:
Look if MSD hasn't replied to you on which connector it is for your car then take the coil off & L@@K at it! It's pretty damn simple & you just have to take off your original coil on your car & figure out which terminal your car takes, whether if it's the round or flat terminal is what you need to figure out. http://www.msdignition.com/coil_blaster_12_8229_8239.htm
Good luck & tell me if it makes a difference!
Later!
