Need Help with msd coil diagram
JOBY_GST
46
Nov 9, 2012
Hormigueros, Puerto Rico
I bought a 1995 eclipse gst with a 6 bolt swap and the previous owner had them install individual msd coils . I would like to know if the wires are installed correctly. I don't have a diagram with color Id and sequence followed to know if they are installed correctly.
Anybody?
I'm going to guess, based on your profile, you're able to change the tuning of each individual coil. With that being said it'll be based off of what the pin-out for that ECU/ECM is, but you most likely also have some type of ignitor module, similar to the stock PTU, that is controlling them since they resemble standard coils.
But to truly answer your question, do you have any other information for us to use?
