need help with apexi turbo timer
zrk666
144
May 13, 2004
louisville, Kentucky
the turbo timer is not running my car after i take the key out of my ignition. i have the greedy harness in place and it is concted to the relay box via connecter. the gray wire is hooked to the green red striped wire on the ebrake. the white wires is tapped into the 02 for the computer pin number 4 on the ecu. the black ground wire is also hooked into the ecu into pin number 106. the readings are comming up on the screen. there are the green, red, and whie wires hanging out on the greedy harnes not connected to anything. should they be connected to something and what? should my ebrake be reading 3 omhs of resistance when the e brake is down and is reading .1 omh when it is up? :cry:
ya got instructions ? did you acualy turn the TT part of it on ?
It can be set to OFF and have everything else work.
i have instructions, everything else works like viewing the oms of resistance and etc... the turbo timing of the car didnt work like the vehicle staying on for 30 seconds after removing the key!
    • dsmmario
    • Detail
    • dsmmario
    • Canadian_CD9A
