Need Help With 6 Bolt Swap ASAP!!
combatmedic
217
Jan 27, 2010
Fountain, Colorado
Correct me if I am wrong but you should not be able to turn the crank by hand once it is attatched to the transmission correct????
Also my timing is set correctly but it is not at TDC, that doesnt matter right??
Yes you can turn the crank by hand if the car is in neutral.
What do you mean that your timing is correct but not at TDC.
