Need help seperating O2 housing from blown turbo
Dom954
Sep 21, 2012
Fort Lauderdale, Florida
Today I removed my blown 14b step by step as described in the tech article for removing a 14b. The only issue is I am having a killer time removing the o2 sensor housing and old oil lines now that they are free and the entire assembly moves when I try to put any muscle on the bolts. Any suggestions would be great.
You could bolt it back up to the manifold with 2 bolts. That would keep it from moving while you remove the oil lines. I would also disconnect the downpipe from the O2 housing and remove the turbo with O2 housing attached. Then you can get to the O2 housing bolts better.
Heres a pic of if pulled from my profile.
showimage.php
I was thingking table clamps but that makes more sense. I'll let you know how it turns out thanks.
http://www.dsmtuners.com/gallery/showimage.php?i=131591&catid=member&imageuser=141142
