Need help running rich
d-meeks
53
Aug 17, 2011
burlington, Wisconsin
Hi dsmtuners, my 95 gst is running really rich when it sets and idles its about 14-15 and then when I rev it it goes rich and back fires and then when i drive it seems like the gas pedel is acting slow and when I start to boost it back fires really bad. Im going to check my compression tommorow and my oil dont look right i think it may have gas in it cant smell it right now since i have a stuffed up nose LOL but i need help asap thanks.
I do have a wide ban and a safc and i have already done boost leak but why would there be gas in the oil? thanks
Yah my wideband is at 14-15 and idle and 17 or just the red marks when i give it gas or drive it.
d-meeks, Higher numbers in your Wideband means lean, sounds like you have some tuning to do with the SAF-C. Do you have aftermarket injectors? Stock MAF? If you are running stock injectors and MAF then zero out all the adjustments on the SAFC and start over, or just go back to running the stock ecu and wastegate boost on your 16g until you can get ECMLink to tune with.
My car has been tuned by king motor sports could a bad o2 sensor be doing this
And its stock maf and injetors.
Do you have a tuning device so you can see whats going on for yourself? So you can see cel then fix them do you have any thing other than a wideband ? Do you have any cels a bad o2 will throw a code plus any other cels that show up.
Order a Innovative motorsports wide band kit (I do not work for them ;D) and then you will have a much better way to tune and figure out what is going on.
He already has an AEM Wideband.. why would he need another wideband? It's not going to tell him any different unless his wideband is bad, he's still going to have the same issues. What are the settings at on the SAFC? It sounds like they didn't tune it properly. Is that how to got the car back from them after the tune??
  • For sale 4G63 Kiggly HLA
    Kiggly HLA $100 + shipping & paypal feesYou must be registered to see element.You must be...
  • For sale 4G63 GSC Billet S3 Cams
    GSC Billet S3 Cams $400 + shipping & paypal feesYou must be registered to see element.You must...
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
