need help - questions and pictures.. head and timing!
blcknspo0ln
DSM Wiseman
7,772
101
Jul 31, 2003
Central, New Jersey
So my waterpump decided to die on me a couple days ago, and I finally got around to pulling the head. safe to say I'm not too happy about the way my valves look. when the cams are perfectly aligned, cyl 2 exhaust valves are open quite a bit, also cyl 3 exhaust valves are open. I don't know too much about how they work, so do you guys think it's normal? Another concern I have is that there was splotches of coolant on the piston heads, I do'nt know if that was from pulling the head, or from coolant getting swathed around while the head was taken off? pictures were taken immediately after we pulled it. Do you guys think the HG was blown, or on its way out? off topic, but I also noticed that the timing belt doesn't necessarily have to pulled in order to take off the waterpump, am I nuts or what?
p.s., taken with my parent's canon 7.2 MP camera.. sure beats my camera phone ROFL
lastly,
When I checked all of my timing marks before I pulled the head, my oil pump sprocket was out of phase. The actual mark on the sprocket was facing about 4 o'clock versus the notch on the front cover at 10 o'clock. would that make a power difference? or any difference at all?
<img src="http://i16.photobucket.com/albums/b39/thelmasofast/enginebayangleshot.jpg" alt="Image hosted by Photobucket.com">
what the hell is this gunk?
<img src="http://i16.photobucket.com/albums/b39/thelmasofast/headgunkcloseup.jpg" alt="Image hosted by Photobucket.com">
<img src="http://i16.photobucket.com/albums/b39/thelmasofast/4pistonblock.jpg" alt="Image hosted by Photobucket.com">
Whats with the coolant?
<img src="http://i16.photobucket.com/albums/b39/thelmasofast/cyl2closeup.jpg" alt="Image hosted by Photobucket.com">
valves..
<img src="http://i16.photobucket.com/albums/b39/thelmasofast/valves.jpg" alt="Image hosted by Photobucket.com">
cyl 3
<img src="http://i16.photobucket.com/albums/b39/thelmasofast/cyl3valves.jpg" alt="Image hosted by Photobucket.com">
cyl 2
<img src="http://i16.photobucket.com/albums/b39/thelmasofast/cyl2valves.jpg" alt="Image hosted by Photobucket.com">
my broke ass waterpump
<img src="http://i16.photobucket.com/albums/b39/thelmasofast/waterpumpangle.jpg" alt="Image hosted by Photobucket.com">
sideshot
<img src="http://i16.photobucket.com/albums/b39/thelmasofast/waterpump.jpg" alt="Image hosted by Photobucket.com">
What's coming in the mail from SBR and mentor mitsubishi?
- New t-belt and all components
- New waterpump
- ARP 7 bolt headstuds
- New mitsu composite HG
- Prothane motor mount inserts
- New gaskets
The head will be thoroughly checked on Thursday and decked also ..
-balance shaft out of alignment just makes the car shake
-coolant on pistons is slosh from taking the head off
-bleed the lifters and those valves will go down
-gunk in your head is from un-frequent oil changes
