Need help now!!!!
ineedagsx
273
Aug 14, 2007
islip, New York
ok so i bought my gst and i bought an extra engine from the same kid, i was going through it to do my engine rebuild (which is posted on here) and the head is non turbo but the block says 4g63 tm5135 and the block in the gst says 4g63 sa8153. the gst is a 95 and the donor engine i THINK is a 99 but the head is definetely a none turbo. when i bought the rebuild kit the pistons were deaper (less compression) then the ones that came out which points to a non turbo but im not sure. really need help bad if anyone knows what to do cause i just paid a buttload of money having the block and crank done... can i still use this engine and just use the old head or do i need a whole new block??? thanx for the info in advance its tuesday night if anyone can call me my number is 631 703 0199 please dont call tomoro i know i shouldnt put my number out but im really stuck thanx guys
~Justin
So is the block assembled or not? You don't know what kind of pistons they are? Is the head a non turbo 4g63 head or a gs head? If the block is okay to use then just find a different head, you can get them for like 100-200.
If the head is from a 4G63 it will work no matter what year it is......I have a EVO head on my 92 6 Bolt Engine, and my roommate has my 92 head on his 7 bolt 95 Talon.........if its a 99 Non-Turbo......It's a 420A Head...a Pic might help :aha: EDIT: and it shouldnt matter if the head is Non Turbo or Turbo as long as you have the Turbo Cams
