Need Help locating The Tial Wastegate Spring Chart
spadepro22
1,206
14
Mar 13, 2008
Seneca, South Carolina
I think I saw a thread on here listing the correct springs for the amount of psi to run for the tial 38mm external wastegate. I can't seem to find it. Help if you know were to find it. If not I plan on running 20-25 psi on a bastard 20g.
Its the new one. If I plan on running 20-25psi, is there one spring that will cover it, or will I have to keep changing it out from 1.4-1.7? Thanks for the link. Seems like if it spikes for some reason the spring might not hold up if it passes the spring boost level.
What's wrong with using a MBC? With a 1.1 bar spring I can run anywhere from 15 psi to 32-33 psi.
I will be using a MBC, just saying if it spikes Id like to have the right spring in to handle whatever it spikes to. Like you stated that your 1.1 bar spring you can run 15-33psi, thats what I was trying to ask. The chart list 4 different springs for different psi from 20-24psi.
