tial wastegate help
silverex
85
Oct 26, 2005
south, New Jersey
finally started doing some wot runs in the galant and everything was fine until i up-shifted into 3rd and could feel the car going slower so i looked at the boost gauge and i was only boosting a couple lbs. The logger showed no knock so i tried one more pull and the same thing happened and it sounded like an exhaust leak. So i baby it to the house and put my had under the dump tube and felt exhaust pulsating out at idle. It also seemed like there was less exhaust coming out the back. So i figured it was the tial 39 ewg. I started pulling it off and noticed that the spring and the diaphragm were in place with no holes or tears. So now am starting to wonder if it is the wastegate. I'am going to mail it out anyway to make sure its all right but does anyone have an idea of what else could be the problem?
Has anyone had a tial wastegate break on them?
do my symptoms sound like a broken wastegate?
What else goes bad on wastegate other then the spring and diaphragm?
if its not the wg any idea what would cause low boost and make a ewg stay open at idle?
thanks for any help
Paul
it was yellow and i think it was the 9psi spring, i did about 20 WOT passes and then it stayed open at idle. I mailed it out to get looked at and they said they would look at the spring to see if it sagin but everything seemed fine when i took it off and if its not the wg i'am completly lost of what else it could be.
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
