Tial Wastegate...
na_turbotalon
180
Jan 27, 2005
Edmonton,
I'm installing a Tial 46mm wastegate and I have no instructions. Seems simple enough but don't want to screw this up. Question is, why are there two vaccum line nipples on it? Do they both get hooked up or do I plug one? Any help is appreciated, maybe a link to some instructuions.
4G63-GST said:
first off, why are you installing such a huge wastegate? unless your going to be running 700+ whp, i dont see the point in it. just use a 38mm wastegate.
He got a good deal on a turbo set up so why not?
If your running a MBC then just hook the line that used to go to the wg acuator nipple to the bottom nipple on the external gate and leave the top nipple open. If you have an electronic boost controller it uses both nipples for better boost responce and such...
