Need help. Injector?? What n where can I find this
Alexonline529
Dec 27, 2020
Providence, Rhode Island
Hi guys,
I just recently got a 98 rs 5 speed. I was told it was a built car but engine sounded weird. Person I got from did not kno how to drive stick. But said engine was built n had turbo n noz but previous owner removed put back to non turbo. My mechanic found a bent valve n bad injector n confirmed engine internals r all aftermarket for racing. Found another valve n changed out. But having problem finding this injector. Said it’s not from car nor the cpu. Any help trying to figure out what kinda injector it is. N where I can get one. Thanks.
they are delphi injectors for a gm. like these
i would replace them with something else. Just google "ford bosch High Impedance ev1 injector" , the ev6 injectors will also work if you change out the connector from a Jetronics type to a USCAR type connector.
