Need help finding rare part
LTUDSM
1,802
7
Jun 27, 2005
Morrisville, Pennsylvania
I took my rear subframe out for rust cleaning ,powder coating and bushing replacement. I took the old ones out using torch was an easy job. So couple days ago I received my new torque solution bushings. As I review the installation ,it says,that I need to keep the original center pin with original cups. I saved cups but I lost all my center pins,that goes inside the bushing. Any ideas of where I could get a new pins???
Ok. Found out the inside diameter 14 mm.mnow I need the lengh. Anyone can measure ???
I'm dropping my rear subframe in the next week or so, I'll be sure to get measurements for you.
...and before you ask, no I won't sell you the sleeves.
:dsm:
...you are talking about the subframe bushing sleeves that are physically in the rubber that's pressed into the bushings in the subframe correct? If so, 2".
:dsm:
Yes,that's the ones. I burned out mines and threw them away. Then when I ordered the new polyurethane bushings ,I realized ,that I had to keep the old sleeves LOL :ohdamn::ohdamn:
