need help finding out where these sensors go on a 6bolt swap
blackawd16g
Jun 4, 2004
riverside, Rhode Island
I am almost done doing my 6bolt swap an need help with these finding out where these go.i know the silve one is one the 2g intake mani.on the drivers side.in the back but not to sure about the ground wire.any help with be greatful cause it is all done besides those sensors.ill post some pics.
my aim blackawd16g.
The little silver thing just gets attached to the intake mani. I used the bolt on the top right corner of the manifold. The groud should go on the tab between the throttle cable mount and the T-Body. It is visible in your pic.
Later
I know, I know its an old post but I think I know the answers here.
the wire with a hole is a ground strap, I would connect that to the intake manifold wherever you can take a bolt out then put it back in after putting it through that ground strap.
The other cylinder looking this is a filter, I was told that it is for the radio and you can bolt this onto the firewall or intake manifold, on the 2g motor it is normally bolted to the intake manifold.
