1G where would these input and output VS sensors go?
1g's use a mechanical speed sensor that drives a cable that goes to the speedo, within the speedo is a reed switch which the ecu uses to determine vehicle speed. That link you posted is for the electronic speed sensor for the 2g's.
They do not drive the speedo. They go on the A/T (pulse generators for the TCM). Part 26422 in the attached file.
So could thes cause bad shifting or sticking gears that sometimes work right and other times dont?
It looks like one goes to the end clutch... but its hard to tell where the 2nd goes
could these cause bad shifting or sticking gears that sometimes work right and other times dont?
Also what would be the difference between the harness with 2 sensors and the individual ones linked here http://www.oreillyauto.com/site/c/search.oap?keyword=transmission speed sensor&year=1993&make=Eagle&model=Talon&vi=1103128
I'm not a A/T expert so I wouldn't know, but I would think unlikely. Take it to a tranny shop for an estimate.
The harness with the 2 sensors is if you need all that instead of just one sensor.
