Need help. Don't know what else to check.
Dsm810z
138
3
Mar 5, 2009
Birmingham, Alabama
I drive a 1992 eagle talon n/t fwd. I've done quite a bit of work on it myself, and the other day it started grinding on start. I kept driving it and then it quit starting all together, but I could hear the fuel pump pushing fuel through the lines. I could get the car to start if I put the car in neutral and played the clutch a little. I've already taken the starter out, and had it tested and it passed so I don't know what else to do. What could cause this?? this is my daily driver so I need some quick help.
Thanks in advance for all your helpful info.
-Chris
Grinding as in the starter makes an aweful grinding sound when you try to start, and the engine doesn't turn over? Probably some teeth worn off the flywheel.
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
