Just don't know!!!!need help
Status
Not open for further replies.
TSI_AWD_95
Oct 20, 2006
Rapid City, South Dakota
K well here's the problem, when i'm aggressively drivin my car and i shift fast right before redline or in the higher RPM's my car like jerks like my motors movin or somethin, it kinda slams, could it be cause i just installed a stage 3 racing clutch, or is there any other ideas, cause i don't know???
Have you checked your motor mounts. Have a friend stand in front of the car while you set your ebrake or hold your foot on the brake pedal. Then let the clutch out slowly and have your friend look to see if the motor moves around. If it rotates back toward the firewall more than say an inch you probably have a bad mount. If this turns out to be true I would by the replacement inserts from prothane and then you wont have a problem again. Keep us posted if you need more help. Travis
Yeah, I'd recommend the prothane mounts if you don't mind a little in car vibration. Could it possibly be that you are simply not used to the new clutch?
Status
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
