General Need help confirming my LC2 wideband wiring before I power it on?
TheodoreMateo
May 22, 2020
United State, Illinois
I read a lot of posts, guides, spoke to friends, looked at the instructions and my FSM, but I am unsure if I did everything correctly. I'm really bad with wiring, but I did my best to solder, heat shrink and fuse as much as I could.
I haven't reconnected the battery yet. I really want to confirm it with you guys first. I have the Innovate LC2 wideband kit, stock turbo ECU, NO ECMlink, welded separate bung for wideband O2, keeping my https://100001.onl/ https://1921681254.mx/ https://happymod.site/ factory and rear O2s in place. My goal is to simply use the gauge to monitor my AFRs for the time being, before I get ECMlink later on. Here's my setup and how I've connected everything:
5amp fuse holder hooked up to Blue-Black ignition switch wire. I checked that it reads no voltage with key off and 12 volts with key to ON
    • george bromwell
    • pma1123
    • Sdcryan1
