1G Need help can’t get the car to start
Msowers
Sep 3, 2023
Lindside, West Virginia
Need help. Have a 1991 2.0 non turbo. The car has ECMlink tuned computer and 450cc Injectors. This is a dirt track car.
I have sent ECU back to ECMTuning to get checked out, it is good. I have three sets of injectors, have replaced CAS. I have fuel to the rail, and have fire.
Car will run on alternate fuel but can’t get the injectors to spray. I also have injector pulse with NOID light. Thanks
Is the injector resistor pack plugged in?
Unless they are plugged or not functioning, that car should run.
My son bought an old Honda and all if it's injectors we're STUCK. They are iron body injectors so I TAPPED on their bodies while running it on brake parts cleaner and they all came to life after 12 years of sitting.
I suspect the injectors if the noid light is working at the connection.
When did it last start up on it's own?
I don’t know. I bought the car not running. I tracked down the guy that originally built the car and he has been more than helpful getting the mess lined out from previous owner.
I have put three sets of injectors in the car. I agree there is no reason it should not run it has my head spinning
I was trying to dig a bit since I can't see how the Noid Light is working but the injectors aren't.
I agree I have had three sets of injectors in the car and don’t see any reason why it won’t run hoping I was over looking something simple that somebody else had experienced
Yes it is plugged in.
So I have constant 12v to both wires in the injector plug ignition on. When I crank the car both wires drop to 9v cranking. Would this be a bad resistor. Thanks
