need estimate on project??
GSX2HOT4U
141
Oct 1, 2002
throwing in a 6 bolt swap, 14b, custom intercooler piping to front mount, 3" turbo back exhaust no cat, act2600 clutch, turbo xs bov, mbc, boost gauge, 255 fuel pump,
what times would u expect from this set up and a 98 gsx w/ tight suspension and possible hp ratings????
First off, add an AFPR and some sort of tuning device (safc, dsmlink etc...) to the mix otherwise you will never be able to take full advantage of your set-up. Second, the 14b is not a bad upgrade; however, if you also added injectors, that set-up could support a much larger turbo.That being said, with the additions I suggested (afpr, tuning) you could probably run a mid-low 13 if you jack up the boost. (depends if you can drive but maybe lower) Horsepower... 250-260 maybe not much more. Good Luck.
exaclty what i thought, i would run like 18psi or so on the stock injectors and 14b, i was thinking it would be around 300 hp at the cranh right and whatever you said to the wheels, that is what i was figuring, then the next step would be a fuel tuner and a big 16g, 22 psi or higher and go get my 12's... what u think?
