Need Electrical Help Please!
blazinglaser_90
95
Jan 24, 2005
uniontown, Pennsylvania
Hey guys
i need some help very badly on my 1990 eagle talon tsi awd
my car is having a major issue, what it is doing is when you go to start the car the starter sounds like its going insane with grinding noises and ect well after the car does start the ignition fuse under the hood is blowing shortly after it starts. Well i figured the circut that starts that turns the starter over inside that cyclinder was blown so i then jumped the starter the car started for a second then blew the fuse again
please help!! i am at my witts end.....the car is totally ripped apart so i can go check wires if any one has any insight
thanks
kevin:dsm:
Remove that starter and have it tested for shorts. If it's ok, then you will need to do some electrical diagnosing. Let's see what the starter turns out to be first.
Good Luck
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
