boost97gst
- 3,034
- 137
- Apr 2, 2012
st jacob,
Illinois
I must say in advance that i've lost interest in this car and barely drive it. Due to my back being blown out, i only built the engine and had a very reputable guy do my gst to gsx swap. He turned my gst into a gsx.
So there's the back story.
Problem is, my 18s wore out rapidly. Inner wear. Way too much neg camber. I found BNIB factory gsx 17s and jumped on em. Very happy with the look. Running 225/45s
I still have the neg camber and it's too much to ignore. From what i can see Jordan(assembler/builder) used new parts everywhere, i really pumped a lot of cash into this thing, and i can see the upper mounts in the rear are shimmed. Maybe....idk 10mm or so. New hardware.
My question is this: Should i go ahead and get longer bolts and an extra 1/4" of washers to shim these out further? I know this would work but i have one worry. If the upper spindle gets any closer to the tire i'm gonna have issues.
I assume the entire spindle/hub/wheel will move as one if i shim this further. Am i correct in that assumption?
The other alternative which i don't particularly like, is a 10mm hub spacer, and longer wheel studs AND i'd still have to shim the upper mounts. Going to try and include pics.
Sitting on Tein Basics and they're cranked all the way up in the rear. Already thought of that.
*One last option would be better coilovers. Seeing how i drive this car maybe 1 or 2k miles a year MAX i can't see dropping another grand on suspension to get a little more height in the rear.
, i will test and see if it works.
