Need Advice- Transmission noise
Swoopkev
64
Mar 20, 2008
Jacksonville, North Carolina
> I own a 1g 4g63 Eclipse GSX
> I hear a noise, a light "kshhhh"
> in all gears except reverse I believe... but
> if I pull the shifter a little left in the same gear it stops
Whats the problem? Or how can I fix it?
Is the sound coming from under the hood or through your shifter cables?
usually this kind of sound is generated by the mains bearings in the tranny ( tapered bearings at the ends of each shafts ) This appear when the bearings got lots of mileage, so cage and roller a worn a bit and get noisy.
The noise seems to be coming from the front right of the car, but like I said leaves immediately when I pull the shifter a little left.
I may try adjusting the cables that is a good Idea.
If it was the main bearings would it stop if I pulled the shifter slightly left??
Yes, that could be a possibility.
Or it could be something in your shift cables raddling!
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
