Need A/T Cooler Insight
nek
832
9
Apr 17, 2009
Pittsburgh, Pennsylvania
Im currently in the middle of installing my short route fmic onto my auto talon and Im hitting a small speed bump, the A/t cooler. Do you guys think its alright for me to rotate the cooler so that the inlet and outlet are facing the ground instead of facing the passenger side? Will the pressure going through the system be enough to push the fluid through going against gravity? LMK Thanks.
your going to be just fine cus the way that the cooler mounts it still have to travel down then up so it doesnt make much of a difference. you may want upgrade a bigger cooler, I happen to have an extra one with fittings. so if your interested.....
