T3rB0
- 0
- Apr 10, 2006
Ronkonkoma,
New York
Hey guys I'm kind of noob so ### don't be harsh on me. I want to say that I have been doing alot of reading on this topic for the past couple days and came down to what I have to ask about now. This will be my first time building a motor so i wanted to ask for your opinions and help on some topics I have.
Heres the deal I just recently totaled my 99 gsx by bending the frame. Good thing is I didn't hurt the motor or transmission in any way. I just baught another 98 Gsx with a bad tranny. So what i'm going to do is swap my tranny from my old car into this one.
Now as for my question: While this new car i baught has a stock 7bolt that works fine with no problems i am going to drive it as long as i can while i build up my 6 bolt motor from my totaled car.
*Things I want to do at machine shop*
-have it bored .020 over.(What is Honed do to a motor, smooth the cylinder walls? If so then since i am boring it .020 i wont need to have it honed?)
-Fully deck the head and block
-Hot tank it 100%
-What should i port on the 2g head? Is it the intake ports? I know the 1g head is bigger.
-Jet washed
-All valves reground
-What crank work should i have them do? (Resurface it?/Balance and polish it?)
*(not sure if you would have a machine shop do these things?So ### let me know) -new oil pump. -new water pump,-balance shaft eliminated with kit,-new valve stem seals and cam seals, and have them pressure check it. Would these get done at a machine shop?
*Internals to get*
-Eagle rods
-Ross pistons (should i ask for them to be .020 over or doesn't matter?
-BC Camshafts 272/272 combo
-BC Springs and TI retainers
-Stainless steel Valves. (should I buy them 1mm over or not and whats the difference?)
-Buy a 1g throttle body
-Clevite main bearings and Clevite rod bearings
-Arp head/Arp main and Arp rod bolts
-Cometic or mitsu metal head gasket
-Cam seals and Crank seals
-oil pump seal
-normal engine set gaskets
- (Should I get new TB tensioner pulley and idler pulley)
-prothane motor mounts
Thats what i have searched so far. Now for some insight on what i have already
-2g stock head
-1g block (6bolt)
-20g
-255 holley pump
-Stock fuel rail
-Afpr with gauge
-Safc2
-aem uego wideband/boost gauge/egt gauge/oil pressure gauge/air fuel gauge
-apexi n1 turbo back exhaust
-MAFT
-680cc injectors
-Boost controller
-suspension work
-short throw shifter
-act 2600 clutch and also another exedy stage 2
- 1 or 2 more small things
Now most ppl say its not necessary to do this but i want to so ### just help me with what im going to be doing. I want to have a street and sometimes track car. My goals are to have 450-500 hp tro crank and 400-450 AWHP
So guys what im asking for is some help on things I should buy or things I don't need to buy from the list I added above. I really appreciate the help
-Hot tank it 100%
-Jet washed
*Internals to get*
-Eagle rods
-oil pump seal
-2g stock head
-1g block (6bolt)
-20g
-255 holley pump
-Stock fuel rail
-Afpr with gauge
-Safc2
-MAFT
-680cc injectors
-Boost controller
-suspension work
PS: why shouldn't I bore is .020 over unless it needs it? Wouldn't be better either way?
