1G NA Air inlet hose
SweetEuthanasia
6
Apr 29, 2023
Halmstad, Ohio
So, ive got to the point where I really need a new cold air inlet hose - md162420 OEM number. The problem is that it doesnt exist anywhere, so I was hoping for the measurements, so i can start looking for an aftermarket part. Mainly inner diameter, but everything else also helps.
The part number you gave is for a non-turbo intake pipe. I have a "hard pipe" on a couple of my non-turbo cars that I can measure for you if you are non-turbo. Let me know and I can pull it off and get you the measurements.
It is a non turbo, yes with the original air cleaner with the sensor and everything
Ok I'll get measurements off of mine when I get home from work.
It's a 3" pipe that I am using. Made it out of a universal kit. I remember I had to buy an extra silicone coupler cuz the kit only came with 1. Pretty hard 90 at the throttle body but probably better than the OG pipe with baffles. And with them being discontinued much better than nothing
Thank you so much :3 when I get her back from the shop for a rad change, im putting in something similar
Where did you buy the universal kit? I have to big tears in my stock intake and it's causing driving issues.
