Resolved 1G Air conditioning drain hose
SrKegler
1,123
37
Feb 29, 2004
Daytona Beach, Florida
Can anyone tell me where the drain line is located on a 1G. My drivers side is getting flooded. At first I thought it was the heater core, bypassed it by looping the lines, dried the floor out and I'm still getting flooding out.
Solution
The evap core is on the passenger side next to the blower motor.
The drain has to be located on the evap case. Remove the glove box it should be pretty easy to see then. Inspect the hose that it doesn't have a hole in it, is clogged, or even disconnected. I'm surprised your A/C even works...that is if its R12.
Solution
Thanks. I was looking all over the drivers side since that was where the water is. No, not running R12. Just had it down for a rebuild so I changed all the seals and converted over to R134 while I was waiting on parts.
