My RS60T just came in...
dsm-onster
DSM Wiseman
8,592
130
Jul 11, 2004
Bloxom, Virginia
Holy He!!. Beside my 16G, this thing is huge!!! We'll she how she reacts to my abuse:thumb: .
I have a question though... It includes an AGP wastegate actuator. Off the top of their head, does anyone know what the actuator's minimum and maximum boost is? Give and take adjustments, can this thing hold to 30 psi no problem or is it really for 15 or 20 psi?
I don't have the RS60T but I do have the RS49T and i can set mine as low as 10psi with no creep at all. I'm running 21psi right now. I haven't tried any higher yet. I think the turbo is awesome and I see 21psi at 3400rpm.
I just deleted all of the replies to this thread that had nothing to do with the original thread-starter's question. 90% of this thread went off topic. He did not ask for feedback on the turbo and he definitely didn't ask what people had heard about it. He asked about the wastegate actuator. If you didn't address his question, you went off topic and your post was removed. We'll be handing out warnings for this next time.
If you want to post a review of this product, do not hijack this guys' thread, use the Product Feedback section in the Tech Guide. For those of you posting "I heard bad things about this turbo" - try reading the rules posted in RED TEXT that are posted directly on the reply form. NO HEARSAY! If you want to complain about a vendor or a warranty, use our partner site, Vendors-reviewed.com.
Thank you Ludachris. You are truely the most active site founder I have ever been in contact with and I use many, many other forums to gather the information I need... I appreciate you're dedication and ability to maintain civility. I apologize, as I feel like I was throwing fuel on the fire through responding to the negativity delivered.
For the record, AGP came on and stated that the wastegate actuator is designed to controle boost from 12 to 25 psi... I think... I can't remember now. the post was deleted:cry: . . .
Yes, they posted between 12-25psi. Good luck and hope you don't have the same issues.:thumb:
Yeah I hope the internal gate works out for you. Comes with a bullseye housing correct? If thats the case you can always upgrade to the high pressure actuator. If you want to find out the lowest possible boost the actuator can run just hook a vacuum line directly to the gate.
I have found with my I/W with 60-1 that it starts to open up above 22psi. You can really see that when logging airflow with DsmLink. Min on my was 14psi and max on wastegate only 19psi. With boost controller at 75% it would go to 25psi..I'm in the process of getting external set up.
Hey 1SloColt! yea it comes with the Bullseye housing. You got a SCM61 recently, right? doesn't that come with a Bullseye housing? Hows she working out for you? Have you gotten your fp2x cams yet?
Yea, I should just test her to find out. that would be easiest.
Well, I may not go above 25 psi. After all, I am still running stock internals. I have very aggresive cams. and dsmlink and enough fuel. I DO have a six bolt. but I guess I want a reliable daily driver that is a killer on the streets. It's a sickness:cry: .
