My engine build PICS
Ok well the project is at a stand still at the moment. Im in the process of selling parts to make money for new ones. Im waiting on the next order to get in so i can almost get the motor finished. But anyways here are some pics of the finished interior and the motor mount on the right way now.
Bryce
Got Parts Today:hellyeah:
Well I got home from school and there it was on my porch....... A box full of goodies. Well of course I went to work and this is what i accomplished today
Well here are the parts I got today. It dsnt look like much but theres about $350 in parts right there
Here is my new oem oil pick up tube and gasket
Thin layer of rtv
and then all bolted down using red loctite
Here are my new oem guide pins installed
new oem timing belt tensioner installed using red loctite here too.
I wish I had the know how to do a full engine rebuild...Looks great!!
Just FYI Bryce, you can now easily turn your posts into Blog Entries with the little "blog this post" icon next to the Quick Reply icon in each of your posts. We're pushing people to post builds like this in Blog Entries instead of threads.
When I started this build I knew nothing about building a block. The most I had done was arp headstuds and a new head gasket. But with the help of dsmtuners and my chiltons manuel I have been able to get this far. I read for days of people saying if you have never built an engine let a pro do it for you. But how are you ever suppost to do it if you never try? And honestly who has that much money to drop into a new motor. remember we have dsm's for a reason.....bc most of us our on a budget. So here I am showing it can be done and let me remind you im only 17;)
Well i hope everyone is enjoying this build and stay tuned for some more work to be done:hellyeah:
Bryce
Why in blogs and not threads?:confused:
Easier to follow along with for those of us who don't want to sift through discussion replies. Blogs are a better fit for those looking to share a project in a journal format. Threads are more for asking questions and having a discussion. In blogs, you can follow the updates more naturally and read the replies if you want down at the bottom. In threads, you have to read through all the replies just to find the updates, since threads are structured more for a discussion, not a journal.
I've covered this in the sticky thread in this forum. Obviously not many are reading it.
I have never made a blog but i can see where it would be helpful. Like the holset turbo threads, there are 6 sections as of now and each section/thread is long as can be. So i had to subscribe to the thread and read each new post to keep up with it or else i'll have to read through everything and all of the good and useless posts in there to get the same info. It seems that the blog section would be good for some cases. I guess i'll have to adapt to more of this new age stuff.
Same here my friend... if people would just get past hating change, they'd see the benefits once in a while (like you pointed out in your reply). For all those who love this site, there sure seems to be a lack of trust in my vision sometimes. Have I ever steered you guys wrong?
And as much as I'm on this site (multiple times a day and everyday unless i'm out of town) i really need to play around with the blog idea cause i doubt it's going away anytime soon.
I just found the BLOG tab at the top tool bar and read the guidelines, seems easy enough. I'll post up a blog if i can ever make it out to the track w/o the rain.
BTW: back on topic, the build is looking really good!
im the same way, people told me to NEVER attempt to do a engine rebuild.. i told them, watch me. im 18 and i knew nothing about rebuilds.. Well i have torn mine down now. Working on sending it to machine shop.. good work bryce. i love the build. Post on my blog let me know whatcha think of mine =)
Ok well its been a week or so since I have updated and alot of work has been done. Im getting so close to dropping the motor back in I can taste it but yet I know I still have a long way to go. Well here is my update so enjoy.
Ok to start off with I ported my OFH since I removed the balance shafts and didnt want my oil pressure 120psi at 5k. So here is the before pic.
And here is it after about 45min or so. Just took a drill bit to it to enlarge the hole then went to a smaller bit to make the top more flat.
Thin layer of rtv on the gasket
And here is the OFH all bolted up.
Bought new coolant lines from autozone.
Next on the to do list was the rear main seal. Here is the order of how all the seals go.
I put a thin layer of white grease on the rear main seal to help it go on. I used a rubber mallot to slide it in.
The oil ring installed. The hole on the ring goes to the bottom.
Put a little grease on the crank to help it slide on easy.
Copper Spray on the gasket.
Gasket installed. I dont have a final picture of the rear main seal housing. I forgot to take one and now the block is back on the stand so i cant take a good pic. But i torqued all the bolts down to 10ft/lbs
Dont forget to rethread the head studs before putting in your arp's.
The size is M12x1.25. I had to special order this tap.
ARP'S installed finger tight.
Got the head back from the machince shop. Got it all cleaned up.
Install your arp washers first if you have aftermarket springs otherwise the spring will block you from putting them on with the head installed.
Molly lube
Copper spray the cosmetic head gasket.
Here is the head installed. I torqued down to 85ft/lbs dont forget to work your way up to 85ft/lbs. I went 30ft/lbs, 60ft/lbs, and the 85ft/lbs
Here is the thermostat housing installed. Use a thin layer of rtv on the gasket.
Here is my 4 layer metal exhaust manifold gasket.
2g exhaust manifold installed.
Cleaned up the oil pan with some degreaser and a little bit of elbow grease. I found so many peices of metal from my balance shaft bearing it was'nt even funny.
Thin layer of rtv on the the oil pan gasket.
Another thin layer of rtv on the oil pan.
And here is the oil pan installed. Dont forget there are 2 little bolts that go to the timing side of the oil pan.
You might have been better off with a bead of RTV around the pan flange rather than that gasket. These cars never used a gasket from the factory, just RTV. Some people have had the aftermarket gasket leak, but it's hit and miss. You may get lucky.
Ok well i have been working on the talon and havnt been updating lately so ill try to catch yall up. To start off with i got my prothane motor mounts all inserted.
I followed this how to on the motor mounts.
http://www.dsmtuners.com/forums/art...install-prothane-mounts-drill-saw-method.html
This is my transmission mount with a pretty big crack in it.
First i drilled holes around the pin untill the pin came out.
Here is the pin once out.
I didnt get a pic of this but use some sort of saw to cut through the metal ring.
once you cut the ring u can begin to wedge something between the ring and the motor mount to get the ring out.
Here is the mount with the ring out.
lube up the mount and press the new prothane mounts in. And then press the new pin into the mount.
Here are the first two mounts
and here is the front and rear mount.
More updates to come.:D
Bryce
Ok well its been awhile since I have updated so I will try to catch yall up.
Here is my new intake manifold gasket
After about a good hour of cleaning
all bolted down. (torque specs are in the chiltons)
Plugging the hole that I used to run my oil line from
bolt, allen wrench, and some thread sealant
Tightened down
New dipstick tube installed along with some water lines.
Bleeding the lifters (vfaq.com for how to)
Lifters installed then put rocker arms on and install camshafts and bolt down to 13 ft/lbs Dont forget to lube things up here.
Valve cover bolted down.
I am currently rebuilding my 16g and porting the hell out of the housing. Ill post pics up soon.
-Bryce
Spectacular work. Nice thread too... I should be bloggin my wrench time as I must drive across canada for family and Targa!! hahah keep it rollin :hellyeah:
Amazing work, let it ride :hellyeah:
I hate to be a debbie downer:cry: but as of post 115 your pistons are in backwards. The bigger reliefs in the valves are suppose to face the intake valves. If it will hit the valves, i dont know, but i thought i would let you know.
Also not a big deal but, the copper spray is made for metal gaskets per permatex. The only gasket that will gain anything from the copper spray is the exhaust manifold gasket you put on. Its no big deal for it to be on the rest but doesn't do anything. Just a heads up! Other than that, great build
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
