My engine build PICS
Ok well im waiting to get some parts still so lately I have just been cleaning parts and just put the motor mount brackets onto the block. Here are some picks of the block with the brackets installed. More cool stuff once i get my new shipment in.
Bryce
yea the shop that I took the block to didnt do a very good job at painting the block black. Honestly the red doesnt show through as bad as it looks in the pics. Now im thinking if I shouldnt go back and do the job myself?
Bryce
I would love to do a build like this but currently i don't have the money. With that being said, I consider myself very lucky not trashing my engine when i spun my balance shaft bearing. Pulled the oil pan, found the bearing fubar-ed, cleaned out the metal shavings, flushed oil through the engine, new front cover gaskets and seals, cleaned everything up, did a balance shaft removal kit installl, painted the oil pan and waterpump pulley and was back up and running. If i would have known how much work that was going be in those few days, i would have pulled the engine out to do it.
Build looks really good, keep us updated!
Well I worked on the talon this weekend and got a little bit of work done. I installed the water pump and here are some pics.
Here is the new oem water pump with gasket and o-ring
I put a thin layer of rtv on both sides of the gasket
Here is with the water pump all bolted down
ok more of the work i got done this weekend. I finished up the bse kit on the front case. Here are some pics of the process hope you all enjoy.:D
Here is the front case with the bse kit already done. Sorry i didnt get any pics of the process but the is a thread on vfaq.com that tells you step by step
here is the bse stubby shaft
Since I am trying to save some money on this build im reusing my front case but im replacing the seals on the case so it works just as good as new. This is the front main seal with a thin layer of rtv around the seal so it doesnt leak.
Just use a rubber mallot and tap the seal in it will look something like this.
Here is the oil seal on the front case its installed using the same method as above
installed oil pump gear with red loctite to 35ft/lbs
Nice choice of eye wear while using a grinder LOL... great build thread. I just finished my engine and bse kit was a pita imo. Anyways good luck with your build.
Here is the rest of the work I did this weekend. Enjoy:rocks:
I greased the crankshaft before putting on the front case
Some copper spray on the front case gasket
Front case installed. Its starting to come together:)
Here is the order of the balance shaft sprocket and crank trigger plate
used red loctite to 60 ft/lbs
I saw this trick on another build thread and thought I would try it and it actually worked pretty well, just stuff rags in untill the crank dsnt spin anymore.
use rtv on this bolt or else you will have an oil leak from here
install idler pully with red loctite to 35 ft/lbs abd finger tight the tensioner pully.
i believe your bse seal is inside out...... but nice work im in the middle of a build because of the same thing....damn balance shafts!! and i hope your oil pump dont take a dump on you....when you do the eliminator kit it tends to raise your oil pressure a little, and depending on how many mile are on that pump it might be good insurence to get a new front case.....i know im going to....
the top part of the seal is facing out which is how everyone elses looks. If i am wrong please tell me. And the oil pump gears all look good so i shouldnt have to worry about the pump going out. and i do plan on porting the oil relief valve bc of the high oil pressure.
And ill flip that motor mount bracket around thanks for pointing that out to me.
thanks,
Bryce
ya the seal is sposed to go in like a freeze plug....it should cup into it....not sit flush, you might be able to get away with it if you use alot of gasket sealer but its still possible that it could leek.
Ok well I have been doing some research on this and it seems many people have done it both ways and as long as you use plenty of jb weld both ways work. So I think I should be ok. If anyone feels this is wrong please chime in and tell me. And thanks to everyone for their help so far.
Bryce
nice!!! well now that your at that stopping point you should start ordering more parts!!! and hahaha way to put the brcket on backwards!!! hehe but its ok
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
