420A My car started up then died won't turn on
Empire19901990
May 7, 2021
Bakersfield, California
Hello I'm new to the dsm life I bought a 95 eclipse with a 420a engine one day I started up the car then it just died now it won't start I changed cam sensor crank sensor ecu asd and fuel relay checked fuses there all good I have to jump the asd relay to get power to my coil and injectors but I don't get no pulse to the injectors or spark to plugs coil works when I send a ground signal to it lil bit of gas in cylinders it backfires a lil when I send ground to coil plus my fuel pump don't turn on unless I jump the relay
have you checked the mechanical timing/timing belt?
The timing belt looks new but I only checked cam timing imma pull the covers off to see the crank timing
