My 97' GSX keeps misfiring after 3000 rpms!! Helppp!
DruSkeez
Aug 6, 2011
Staten island, New York
My 97' GSX KEEPS POPPIN (misfiring) & STUTERING after 3000 rpms and its driving me crazy
I know I need a tune becuz the turbo was upgraded to a 16g and bigger FMIC
But is there anything else is could possibly be? That I can try to fix before I get her tuned???
Im changing spark plugs tomorrow
ANY INFO IS APPRECIATED
Is it doing this under hard acceleration, or just when cruising? An audible misfire means that the air/fuel mixture is being ignited after the exhaust valve has opened, possibly somewhere in the exhaust system. Check your ignition timing, as well as the valve timing. A boost leak test is always a good idea, although I don't think you're even spooled enough at 3K RPM to actually have any boost to leak.
6 bolt swap? CEL P0300? Stock 7 bolt w/ upgrade clutch or flywheel?
Or maybe you just have a boost leak and you're describing poor performance beyond 3000rpm(boost)? Can you describe your problem in further detail maybe?
Also, please fill out your vehicle profile.
Yeah, ^^^ what he said. Your description is pretty vague. If you want us to help you, help us, help you...and show meeee the money!!! ;)
seriously though, we can't help you if your profile isn't updated or the problem isn't described in better detail.
- DOHCTA
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
