2G 97 gsx shuts off after hard pull
turbotalon31
386
3
Jan 9, 2010
reading, Pennsylvania
im working on a 97 eclipse gsx. i put a new motor in its runs and sounds good the only issue im having is when u run it really hard like a block long first and second gear pull. when u come to a stop it shuts off. just cant seem to figure it out any ideas ???
if you just finished doing the swap there is a learning period on the ecu where it will cause it to stall when coming to a stop try driving it smooth for about 5-10 miles and then see what happens
what if mine does that as well .. but not a rebuilt engine.. and also bov is not recirculated.
it is basically a stock 2g with the exception of an evo3 16g and a hks bov. stock massair , 510 injectors , adj. fuel regulator , and thats it
