misfiring after 30 seconds of driving
jeff72496
Apr 10, 2016
Pascoag, Rhode Island
So I was driving and all of a sudden my car lost power and was misfiring. I didn't have a scanner on me but I pulled into an auto zone and they checked it for me and it said "random multiple misfire". So it started misfiring and then I pulled over and it idled rough. Then I shut it off, wait for about 30 seconds to start up and it's completely fine then drives fine for about 30 seconds and starts misfiring again. My plugs are fine and I already changed my wires last October so I doubt those are junk. Any ideas?
Yeah I know that LOL. Is it something easy? I found out where it is in the engine bay. But not sure exactly what I replace. It looks like a plug
I must be looking at the wrong part then cause I don't see any bolts near it. Is it right next to the fuel rail?
Use a scanner and check the voltage of your Upstream O2 sensor also. I had close to same issue and it was my O2 sensor constantly feeding a low voltage. Or just unplug the sensor and see if it still misfires after 30 seconds
Check the harness that connects to the transistor unit because they come short from the factory and can wiggle loose.
I've even heard of the pins coming loose inside of the harness connector
Also while your at it check your injectors for cracked pintles , I got a code though for (injector malfunction)
Do you know if it's running on 2 cylinders?
You can check buy quickly pulling injector connectors and listening for a change in idle or no change
+2 on the Power transitor, my 2g acted the same way ... replaced this and that only to find out it was that damn transitor, I grabbed one from a donor car and off I went.
I posted before explaining what happened. Basically my car starts up fine. Let it warm up, then I'll drive it for 1/4 mile thwn the car will just feel like it's misfiring really bad. Then I'll pull over and it'll idle terrible. I'll shut it off and it turn it back on it'll be running perfectly fine. I changed the power transistor and it's doing the same thing. But while the car was misfiring I disconnected each injector 1 at a time. Nothing changed when I unplugged cylinder 4. But when I unplugged 1, 2, and 3 the car was about to shut off. So it's definitely something with cylinder 4. Something with igniton?
That's what I figured. My buddy insisted I get a compression test. But I had one done last October and it came up to be perfectly good
Believe it or not i had same prob turns out it was a lifter that would lose psi when it got warm easy thing to do for you for start is by new plugs n swap injector over to other cyl its free then pick up a set of lifters u can change them out with out doing timing but its a pain
I've also seen wiring in the harness go bad mid way to the ECU. Depends on how nice your harness is obviously but a wire could have been pinched and separated internally over time. Check all the plugs with a DMM and make sure they're all giving you the same reading.
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
