My 91 GSX Build...
chet
92
Jun 28, 2003
St Petersburg, Florida
Well...i've posted this in a few other forums...figured i'd post this here as well. Some of you can probably appreciate how clean this car is...and how lucky i was to find it.
Well, after purchasing a house and getting rid of a few vehicles...i'm finally able to start on my 91 gsx. The goal of this car is to make it a fast, reliable, easy to drive second vehicle with cold ac and somewhat soft suspension. Every part on the car will reflect what i've learned (or failed to learn) from screwing around with dsm's over the past 3-4 years.
I'm also including a price list to help illustrate what this costs.
I purchased the Tan Car for 1100.
I purchased a Parts Car for 1100. (came with motor, transmission, shocks/springs/exhaust/downpipe, supra fuel pump)
4bolt Rear: 275
extreme PSI FMIC: 850
shep tranny: 1800
Twin Disk Setup: 700
New Brake Pads: 100
New Rotors: 100
Total Price So Far (a few things i've yet to buy...but will)
~6000 Dollars
Current Plans for the car are as follows...with a brief description why...
Good Condition 4g63 (stock rods, stock pistons, new headgasket, new belts)
Shep Tranny (most likely a stage 3 with 4spider center differential)
Quartermaster Twin Disk (pedal feel is softer than ACT, more forgiving)
2inch lowering springs, Tokico Shocks (from the parts car i purchased)
2.5 inch downpipe, 3inch exhaust (enough to make 350-400whp)
Evo3 16g (will make 350hp at 20psi)
Extreme PSI FMIC Setup (fits well, reasonably priced)
4bolt rear (stronger than the 3bolt rear)
Twin Piston Front Calipers
here are a few pics...
installed a 4bolt rear...friend of mine did most of the work.
i was busy taking pics...and ended up selling my 95 gst to someone while the 3bolt was out of the car.
with a shep tranny, twin disk, this car will be reliable to 500whp.
and a pic of mike's jdm lancer...and a link to more pics.
http://honda-tech.com/zerothread/1781460
Shocks/Springs are installed. (KYB Adjustables, H&R Springs)
Also installed a 3" Thermal Catback exhaust. (i painted the muffler black to attact less attention)
Here are a few pics. (put talon wheels back on the car...for now...i think they look better.)
Anti-Lock Brakes are getting removed...
along with all plastics, smic, fog lights, etc...which i won't be keeping on the car.
radiator, fans, lights...etc...were all removed to make pulilng the motor easier...
more to come...as i make more progress
thats a nice looking dsm, my brother just picked up one the other day exactly like you same color and year. we are going to do a jdm swap in it. good luck!
pulled the motor out...
tranny is going to get built (4spider center diff, upgraded synchro's...)
cleaned the engine bay...
picked up a turbo for the car...(MHI evo3 16g)
picked up an evo3 o2 housing...
they will be dropped off later this week at a1 ceramic coat...
uninstalled the ABS...(i was dreading this...turned out to be not so bad)
a few more small updates...
just ordered 1300 dollars worth of stuff from www.extremepsi.com
including their fmic race kit (garrett core) and some misc things i need for the turbo (gaskets, oil feedline, oil return line, etc)
also...i detailed the interior after installing new shift cables and a new momo shift knob...
then i began porting the 2g manifold and evo3 exhaust housing...but the carbide bit broke...
What kind of paint did you use on the Thermal? How long does the company say it will last?
i used high temp ceramic paint from discount auto. i've used this paint on mufflers before and it seems to hold up really well. keep in mind that i'm basing this on beautiful florida weather where we don't see any salt, ice or harsh winter like conditions which may contribute to paint failure.
a few more updates...
things are really coming together now.
Built 91 Tranny is together, with upgraded synchros and 4spider center diff.
Clutch setup (quartermaster twin) is together)
also pictured...is the tilton setup i'll be running in the white car.
...the fmic showed up today.
from extreme psi...
core measures 28 x 12 x 3.5...
I love build threads. You got a heck of a good deal for what appears to be a pristine 1G. Paint, interior, everything looks really good.
Keep us updated on your progress, everything looks awesome so far though!
Good looking car and a great thread to go with it. I kind of wait around like an expectant father waiting for the finished result but it's worth it.
Nice job so far Chet.
Cheers,
Andy
Cheers,
Andy
believe me...i've been ready a few times to just have the car be finished. fortunately, its lack of time that is keeping me from finishing the car...not money.
i have spent more than i expected...but i think that is always the case...plus i wanted to cover my bases completely and make the car jsut the way i wanted it from the very beginning.
in other words...i hope to do it right the first time...and down the road add rods/pistons/3052 or something similar along with aem etc.
i want the car to retain ac, and i want it to retain all of the nice features a daily driver usually has (in order to keep the gf happy...who puts up with the hobby...at least to a certain extent) although...this is how she usually looks when i spend too much time working on these pieces of shit. (i call it, the "i'd rather be at the mall shopping...than sitting around at the house while you work on your stupid car" look)
brand new driver's side motor arrived today...
also installed the fmic today.
tomorrow, the axles, starter, t-case and wiring harness all go back together...
here are a few more pics.
it was garage kept...as best i can tell...
it was also stored at my facility for about 6 months...
otherwise, it was just taken care of and not abused...ie girl driven.
slim fans arrived...
and the 90 air cooled oil cooler is also mounted...
anyone know where i can get aftermarket lines for the oil cooler?
i'd like to put the cooler here...but the lines are barely long enough to reach the oil housing.
it all fits...barely...haha
and a pic of the bumper cover in place. i need to adjust the hood...
Aftermarket lines for oil cooler? Could you possibly rig up a stainless braided hose? Btw, you gonna put the fogs back on ;). If not PM me.
i think i threw the fog lights out...but i can check.
i've located some lines for the oil cooler...and should have them by monday or tuesday.
next, is installing the 2g big brakes and front axles...and wiring up the 10'' slim fan.
monday is also the day when all of my stuff comes back from the ceramic coater...
installed the passenger side dual piston calipers/rotors/hawk brake pads. just discovered the driver side wheel bearing needs replacing.
now i'm off to the a1 ceramic coat to pick up my IC piping and exhaust manifold/housings...etc...
everything just came back from a1 ceramic coat...
