tranny problems in my 91 gsx
Tru21T
Dec 19, 2005
Stephens City, Virginia
hey i have a 91 gsx i just bought the guy put in new bushings thinking that was what it was then i thought it was just the linkage out of line but it aint what it does is grinds in second and third gear unless im sitting still then it is fine i can go threw all gears without out a noise please any suggestions help thanks alot:dsm:
Your synchro;s are probably going out. You will notice this at higher rpm's like when moving and whatnot but sitting still it will go right into gear. I would drain your fluid and see if it has any metallic color to it and put fresh fluid in. This might help for a little while but if the fluid comes out with some shiny little spots that migth look like metal then there is no getting around it.
